Terry6
1 year agoCyclone 10 LP reverting to factory image unexpectedly
I have a design with both factory and application images. On power-up everything works as expected, the factory image is loaded, then the application image is loaded. I'm using the Remote Update (RU...
FvM
1 year agoHi,
I would generate an GPIO signal in parallel to the Watchdog Reset and check with oscilloscope (time width trigger) if the reset period has outliers.
