Cyclone 10 LP LVDS capability
general answer is yes, Cyclone 10 LP can achieve at least 640 MBPS LVDS data rate (with slowest speed grade), review datasheet.
The question is however no very clear, are you referring to data rate or DDR clock. It's also important to know how the receive clock is provided, e.g. sent to the FPGA along with the data? Extracting clock from received data (CDR) isn't natively supported by Cyclone 10 LP FPGA family.
- davekrzy2 years ago
I would be trying to use a receive clock provided to the FPGA along with the data as well as a frame valid signal. I am using the IP core and was wondering how do you define the connection in the vhdl file. Looks like the IP only defines 1 side of the input pin, so do I only need to define 1 pin input at the top level as well?
IP snippet
component LVDS_RX is
port(
rx_in : in std_logic_vector(0 downto 0);
rx_inclock : in std_logic;
rx_out : std_logic_vector(7 downto 0);My top level snippet
entity TopLevel is
port (nrst : in std_logic; -- active losclkin : in std_logic;rx_in_sig : in std_logic;);
end TopLevel;Thanks!
