MK_ABQ's avatar
MK_ABQ
2 years ago
Cyclone 10 LP FPGA
I would like to know the following two things about Cyclone 10 LP - 10CL040YF484C8G
1) Which quartus versions support this FPGA?
2) What is the core fabric speed of this FPGA ( Speed grade 8 is slowest as per part number),
but I would like to know the speed in Hz.
Datasheets/user guide doesn't seem to mention it. Can you help?
  • Hi,
    you find Cyclone 10 LP maximum core clock speed in datasheet, C8 402 MHz, I8 362 MHz
    The device is supported by all recent Quartus std or lite versions, I believe starting with V17.0.
  • Hi,
    FVM answer is verified. Hope you can now proceed with your design. It is recommended to use the latest Quartus version for new design.
    Aiman
  • FvM's avatar
    FvM
  • wuyuetian's avatar
    wuyuetian
    Regarding the issue of 10CL040YF484C8G $100 discontinued replacement large quantity ordering, we have set up a special team to conduct research and achieved good results. Are you interested in joining?
    Email: [email protected]
