jfletch
6 years agoCyclone 10 LP Configuration Voltage Standard
Can the configuration bank on a cyclone 10 LP bet set at 1.8V when using Passive Serial configuration? Table 44 in the Core fabric handbook (c10lp-51003.pdf) suggests that the Configuration Voltage ...
YuanLi_S_Intel
6 years agoApologize that it cannot be. Configuration bank (I/O banks 1, 6, 7, and
The reason is that it will affect the device bootup and configuration.
Mike311
5 years agoI've run into the same issue with using passive serial but trying to drive it with 1.8V from a host processor. Looking through the documentation and device pinout spreadsheet it's not clear to me why bank 7 also needs to be configured for 3.3/3.0/2.5V. Can you confirm that bank 7 requires 3.3/3.0/2.5V for PS configuration?
