8 years agoCyclone 10 GX EMIF PLL clock input
After compiling a EMIF for Cyclone 10 GX, I noticed that it insists on using an external differential clock. Attempts at routing internal PLL output to pll_ref_clk input results in error. Does that...
8 years agoHi,
--- Quote Start --- After compiling a EMIF for Cyclone 10 GX, I noticed that it insists on using an external differential clock --- Quote End --- • This is user configurable option in C10 EMIF IP under PLL refclk section. • Set in EMIF IP thenuse the IO standard that being set in EMIF IP. --- Quote Start --- Attempts at routing internal PLL output to pll_ref_clk input results in error --- Quote End --- • Yes, this is expected. C10 EMIF PLL refclk need to come externally from board. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
