8 years agoCyclone 10 GX dev kit LVDS loopback
I am trying to create FMC loopback with LVDS assignments on Cyclone 10 GX development kit. Please see the problem I came across below
first, to achieve this goal, i need to use the following ip: https://www.altera.com/en_us/pdfs/literature/ug/ug_altlvds.pdf updated for intel quartus prime design suite: 17 (https://www.altera.com/en_us/pdfs/literature/ug/ug_altlvds.pdf) www.altera.com 1 LVDS SERDES Transmitter/Receiver IP Cores User Guide The low-voltage differential signaling serializer or deserializer (LVDS SERDES) IP cores https://alteraforum.com/forum/ad20bd2d-7839-4380-98ab-223d30445bd5 second, to use this ip, i need to use one of the following 2 tools: 1- IP Catalog 2- Platform Designer Please see two separate sub-problems when I try to use these tools: problem 1a- "ip catalog" "IP Catalog" option under tools menu in both Linux and Windows version of Quartus Prime Pro 17.1 is not functional. When it is clicked on it, nothing happens. https://alteraforum.com/forum/cb55f7d8-b4dc-46d8-8299-a13980a0c033 I am trying to use the following IP : but it is not available through "ip catalog" or "platform designer" https://www.altera.com/en_us/pdfs/literature/ug/ug_altlvds.pdf updated for intel quartus prime design suite: 17 (https://www.altera.com/en_us/pdfs/literature/ug/ug_altlvds.pdf) www.altera.com 1 LVDS SERDES Transmitter/Receiver IP Cores User Guide The low-voltage differential signaling serializer or deserializer (LVDS SERDES) IP cores https://alteraforum.com/forum/42755398-509d-4390-8f7a-4de5508d4f03 problem 1b- Platform Designer It (IP Block ug_altlvds ) is also not available under "platform designer": https://alteraforum.com/forum/fc74a68f-dfc2-4b66-9d3e-f53d6f168c9f1 Reply
It sounds like there is something wrong with your installation of Quartus. Which edition are you using (lite, Standard, Pro)? Cyclone 10 GX is only supported in Pro.
