Sumanth
1 month agoCyclone 10 GX AS x4 Configuration Compatibility with Infineon S25FS512S (Custom Flash Definition)
We are trying to use the Infineon S25FS512S QSPI NOR Flash with Cyclone 10 GX in Active Serial x4 (AS x4) configuration by creating a Custom Flash Definition based on AN229767. JTAG programming comp...
Farabi_Altera
1 month agoHello, do you have further question?
- Sumanth1 month ago
Hello Farabi,
Thanks for your response. I don't have any questions at the moment. I'll try your suggestions and get back to you if I need any further assistance.
- Farabi_Altera1 month ago
I will close this case first, if you have question, plesae raise new forum case. I will support you.
regards,
Farabi
