14 years agocyclone 1 with byteblaster
i am using altera cyclone 1 with byteblaster cable if the bank containing jtag pins has vccio 2.5v so i will have to connect the vcctarget of jtag to 2.5v and if so the input minimum voltage of j...
14 years agoByteblaster II and USB Blaster have been designed to handle these low IO voltages. Original ByteBlaster requires a 5V supply according to the utilized 74LS driver, ByteBlasterMV needs at least 3.3V supply, altough VCCIO can be lower. Read the comments in the respective ByteBlaster datasheets. A possible solution could be an on-board voltage translation buffer for TDO.
Do you have a 3.3V supply available on the board?
