12 years agocyc4 JTAG AS config questions
I am using the EP4CGX30BF14 device with an EPCS16SI8N flash and a JTAG connector. I'm using Fig 8-29 from the handbook for my setup, so SFL and only one JTAG connector. I'm a bit confused on a couple...
12 years agoThank you Alex for taking the time to respond. Your post solved it for me. I normally select the same voltage for both banks just to avoid this issue. I couldn't avoid it on this project and the handbook confused me.
v/r, Shannon
