Rk_Athram
4 years agoCTLE AC gain equivalent values in db for Arria 10 Transceiver tool kit
I am using Arria 10 GX dev kit. we are using transceivers in our project. In transceiver tool there is an option for changing CTLE AC GAIN in terms of Numeric /numbers. I need to know how mu...
Ash_R_Altera
4 years agoHi,
There is no similar sheet for the Rx side. However, you may use tools like Transceiver Toolkit to view the impact of the changes to TX parameters on RX side.
The CTLE gain at RX in dB depends upon the data rate and the setting. Values can be found in the datasheet: https://www.intel.com/content/www/us/en/docs/programmable/683771/current/transceiver-specifications-for-gx-sx.html
