AlehTS
5 years agoCSI-2 receiver
Hello.
I am designing CSI-2 receiver on Cyclone 10LP device. The data are comming from sensor.
CSI clock is about 350 Mhz, 4 data lanes.
At the data inputs I use altlvds_rx. Due to high data ra...
AlehTS
5 years agoUsing LP signals I can determine the mode change events.
I am thinking about using "pfdena" signal to disable input detection during low power mode.
The second thing I am thinking about is using "Switchover". I'll use interanlly generated clock with allmost the same frequency as a "backup" clock.
But I am not sure how fast the pll can switch between close frequencies or lock after pfd is enabled.
