FXion
8 years agoCritical Warning (16248): pin is placed too close with ADC pins.
Device: MAX 10 10M08DAF256C8G Quartus version: 16.0.1 build 218 I kept receiving this critical warning message even I removed lots of redundant pin assignments to keep my design at a minimal level....
bitwise
8 years agoSince you already have the board, you can trick the fitter using the following qsf assignment:
set_instance_assignment -name IO_MAXIMUM_TOGGLE_RATE "0 MHz" -to SystemStop
This tells the fitter that it's a static line which won't introduce transients into your analog signal. If that's not the real case you'll still have the noise issue of course but the fitter will be "happy".
