17 years agoCreating GUI
hello,
I am using altera DE1 board.I am trying to create a simple GUI and display it on the monitor. I am trying to create a GUI in NIOS using c language. How should i build the SOPC in order to display my GUI on the VGA monitor. please can anyone suggest me how to create a simple gui in c with an example. thanks in advance4 Replies
Hello
Thanks for your reply. The main problem is with my board. I am using DE1 board. Please suggest how to change my SOPC so that i can display my GUI on the monitor. Whatever the link u have send is for Stratix board. - Altera_Forum
You can have a look at the following demo.
http://www.altera.com/support/refdesigns/sys-sol/computing/ref-niosii-vga.html though, its for different board i suppose. But the software will give you idea about the simple graphics libraries. I think, you will have to combine the understanding of reference design for DE1 board and the one in above mentioned link. Regards - Altera_Forum
Hello
can anybody suggest me how to do it with an example code... - Altera_Forum
--- Quote Start --- hello, I am using altera DE1 board.I am trying to create a simple GUI and display it on the monitor. I am trying to create a GUI in NIOS using c language. How should i build the SOPC in order to display my GUI on the VGA monitor. please can anyone suggest me how to create a simple gui in c with an example. thanks in advance --- Quote End --- Hi, If you want to display just GUI on the VGA monitor, you will need a frame buffer allocated for VGA frame in memory. Use Nios to write your GUI in that allocated buffer memory. You will need SGDMA to transfer the frame from memory to the VGA controller. Run this SGDMA in continuous transfer mode. hope this would help.
