13 years agoCreating a waveform in Modelsim
Hi, I'm attempting to use Modelsim for the first time. I'm following the tutorial 'Introduction to Simulation of VHDL Designs Using ModelSim Graphical Waveform Editor' by Altera found at -...
11 years ago --- Quote Start --- The latest tutorial to "not work" is a simple one --- Quote End --- Rather than attempt to use a non-working example, I'd recommend taking a look at the examples I've provided in the links back at the start of this thread. Using the waveform editor to create stimulus is a bad idea. The technique is useful in a very limited number of situations, and even then, since you can write HDL code to create the waveforms, I'd argue that its never useful. Cheers, Dave
