13 years agoCreating a waveform in Modelsim
Hi, I'm attempting to use Modelsim for the first time. I'm following the tutorial 'Introduction to Simulation of VHDL Designs Using ModelSim Graphical Waveform Editor' by Altera found at -...
11 years agoHi Dave,
The latest tutorial to "not work" is a simple one here (ftp://ftp.altera.com/up/pub/altera_material/12.0/tutorials/verilog/modelsim_gui_introduction.pdf). I thought "if I can't get this to simulate (using the supplied instructions) then I need to change my approach", such as learn to write a test bench module. My problem was that the Create Pattern Wizard as illustrated on page 9 never appeared: On page 8 the instruction is "in the Objects window, right click on X1". When I do so, the pop-up menu choices are add wave and add wave new. Nowhere does create wave appear, and what does appear does not have the same functionality. I was running the Altera version of ModelSim as a stand-alone program.
