13 years agoCreating a waveform in Modelsim
Hi, I'm attempting to use Modelsim for the first time. I'm following the tutorial 'Introduction to Simulation of VHDL Designs Using ModelSim Graphical Waveform Editor' by Altera found at -...
11 years ago --- Quote Start --- I am just now struggling with the exact same issue. I am glad it is just not my overlooking something, though that does little to reduce the frustration of hours spent so far trying to get the "tutorial" to work! --- Quote End --- Which "tutorial" are you struggling with? If you can be a little more specific, I can probably help reduce your frustration :) Simulations that involve HDL code only and Modelsim are pretty easy to deal with. Simulations that involve Qsys generated projects are more complicated, since Altera's tools generate the Modelsim script and its not that good. Cheers, Dave
