13 years agoCreating a waveform in Modelsim
Hi, I'm attempting to use Modelsim for the first time. I'm following the tutorial 'Introduction to Simulation of VHDL Designs Using ModelSim Graphical Waveform Editor' by Altera found at -...
12 years ago --- Quote Start --- Thank you Dave once again. I would like the simulation process to be as simple as possible at the moment. I feel that even though a test bench will probably be the better solution later in the project, i feel that it has a steeper learning curve to be able to get up to the stage where i can comfortably simulate a project without spending a considerable amount of time on it. Although at the moment, i'm considering on just reverting to the inbuilt Qsim in Quartus which is the old waveform simulator found in version 9.0 and earlier. Purely because even though i do each and every step in a few tutorials i've seen, the 'Create Wave' option on the right-click of an object just doesn't appear. Like i said before i think i'm probably missing a vital key in the simulation process that's not mentioned in the tutorials i've seen. . --- Quote End --- hi, i had the same issue, i'd like to ask if u have found a solution regards :)
