14 years agoCRC jam file
Using the jam file below ------------------------------- NOTE MAX_FREQ "10000000"; ACTION CONFIG_IO = EXECUTE; PROCEDURE EXECUTE; BOOLEAN X = 0; DRSTOP IDLE; IRSTOP IDLE; STATE IDLE; IRSCAN 10, $015; DRSCAN 32, $FFFFFFFF; STATE IDLE; EXIT 0; ENDPROC; ----------------------------- I simulated the above jam file using quartus_jli.exe (command line jam player), it gave me output as ---------------------------------------------------- Expected CRC not found, actual CRC value = AB60 Export: key = "JAM_STATEMENT_BUFFER_SIZE", value = 1051 NOTE "MAX_FREQ" = "10000000" Exit code = 0.. Success ----------------------------------------------------- Using the above JAM file, I modified the line# 9 to an arbitrary number ("1FFFFFFF1"), to change the CRC checksum value and i got the output as ----------------------------------------------------- Expected CRC not found, actual CRC value = 493F Export: key = "JAM_STATEMENT_BUFFER_SIZE", value = 1051 NOTE "MAX_FREQ" = "10000000" Exit code = 0.. Success ---------------------------------------------------- In this simulation, I am not able to understand the "Expected CRC not found" instruction. Can anyone please help me about this problem and suggest me the solution. Thankyou in advanceNo RepliesBe the first to reply
