Jacob494
1 year agoCRC Error without Pull-up Resistor
Will the CRC Error Pin be driven high by the FPGA when a CRC Error occurs, even if no external pull-up resistor is present? (Assuming "Enable error detection CRC" is enabled and "Enable open drain on...
FvM
1 year agoHi,
I feel the device handbook is pretty clear about CRC error pin operation with open drain disabled.
"To set the CRC_ERROR pin as output open drain, turn on Enable open drain on CRC_ERROR pin. Turning off this option sets the CRC_ERROR pin as output."
