14 years agoCRC_ERROR pin on DE2 board
Hi I enabled the error detection CRC in the device and pin options dialog box mentioned in AN 357. But how to find CRC_ERROR pin on DE2 board.
14 years agoHello,
I will be more clear. If after you do all this discovery and determine that in fact the USB is already using the pin that you are looking to use, then; you will NOT be able to use that pin to look at the CRC_ERROR condition (and should not set the tools to do that). Make sense?
