14 years agoCRC Calculation - VHDL
Hello to all forum members!!! I'll be glad to get your's suggestions to solve my problem. I am interested to make the CRC Calculation as fast as possible (without using the MegaWizard function)...
14 years ago --- Quote Start --- CRC16 can be reduced to the following C:
uint32_t
crc_step(uint32_t crc, uint32_t byte_val)
uint32_t t = crc ^ (byte_val & 0xff);
t = (t ^ t << 4) & 0xff;
return crc >> 8 ^ t << 8 ^ t << 3 ^ t >> 4;
Which can trivially be converted to VHDL: t1 <= crc_in(7 downto 0) xor data(7 downto 0);
t2 <= t1 xor t1(3 downto 0) & B"0000";
crc_out <= X"0000" & (X"00" & crc_in(15 downto 8)) xor (t2 & X"00")
xor (B"00000" & t2 & B"000") xor (X"000" & t2(7 downto 4));
Which is 4 levels of XOR. As I said earlier, if you really need to generate the CRC of a 53 byte buffer in parallel every clock (I can't imaging why!) then you probably need to make use of the linearity of CRC calculations. Basically, if you CRC random data, then change a single bit, the difference in the CRC is independant of the original data. So, for a fixed length packet, you can easily determine which CRC bits each input bit changes and xor those values for every set bit onto the CRC for an all-zero pattern. --- Quote End --- Thank you for response :) My target is to send data packed with rs-485 communication protocol. Every 10mSec I send the packet. As I said before, packed build from 53 bytes and 2 bytes of CheckSum. Before, I used the MegaWizard for CheckSum perfomance and it was done during one clock cycle. At CheckSum I'm interested to change with CRC. That's the reason for CRC calculation. As I have read from different posts, CRC suitable for such a long data packets. Am I right?
