8 years ago
CPLD(EPM1270-F256) I/O Status
I'm using EPM1270-F256(ALTERA MAX II CPLD) in Ultrasound system control pannel
K6 of I/O port is used input port.
That is connecting with switch and PC power signal.
That i meane checking switch action.
I knew that I/O port is floating in normal status.
But, I had seen that port short with internal GND in CPLD.
So, I would like to how I/O port can that status.
What case cause that status(short with GND?
    Do you actually use the signal, that goes in on pin K6, in your design? Even if you specify that it's an input at your top level, unless it's used for something it will be treated as unused.
    Cheers,
    Alex
    Thank you for reply.
    I had defined K6 port used pin and be input.
    That means K6 is floating status.
    But it changed status that short with GND.
    So, my question is what case cause to change I/O status.
    Son.
    In the project settings you can set all unused I/O to connect to GND. That may be the case.
    If so, it will be fine to use this pin for a new input signal.
    Cheers,
    Alex
