8 years agoCPLD(EPM1270-F256) I/O Status
I'm using EPM1270-F256(ALTERA MAX II CPLD) in Ultrasound system control pannel K6 of I/O port is used input port. That is connecting with switch and PC power signal. That i meane checking swit...
8 years agoIn the project settings you can set all unused I/O to connect to GND. That may be the case.
If so, it will be fine to use this pin for a new input signal. Cheers, Alex
