19 years agoCPLD: measuring the performances
We have programmed our CPLD and now we would like to test if our design is valid and the system performances. I am just writing and reading values in our registers and checking if it is Ok, but I wou...
19 years agoOr you can connect the output pin to the internal ocsillator of the MAX II device and when the device goes into user mode, you should see the output pin toggling at around 5MHz. You can intantiate the oscillator with the alt_osc megafunction.
