Neha
5 years agoCPLD Max V equivalent gates
I am checking for an alternate to replace EPM3064A. I see the actual gates are mentioned as 1250. I dont see this "actual gates" count given in Max 5 OR Max2 series CPLD. Instead we have L...
Neha
5 years ago
Per the above sanp from MAX3000 specification sheet I see that there are 1250 usable gates. I am trying to figure out an equivalent CPLD that can replace Max 3000 part.
In Max 5 series if i see, then I have the basic unit as LE(logic elements). Should I take 1270 LEs part 5M1270Z to replace EPM3064A(1250 actual gates), comparing actual gates value with LEs?
Is LEs and actual gates value of these two different spec sheets comparable for selection of alternative in CPLD?
AminT_Intel
5 years agoHello,
Yes they are similar things.
