RHark
7 years agoCPLD Configuration Architecture
In CPLDs, is there a difference between Configuration Memory and Program Memory? I understand that FPGAs load data from a non-volatile source into the LUTs, and I'm wondering if CPLDs do something s...
ShafiqY_Intel
7 years agoHi RHark,
Configuration Memory and Program Memory are similar. Some people called it Configuration memory and some called it Program memory.
When you read back the configuration memory of a MAX V CPLD, it returned the exact programmed values bits but the orientation of bits might be different from the programming file. This bit differences due to Little/Big Endian or LSB/MSB.
I hope this help.
Thanks. 😉
