9 years agocpld and parallel flash
hello im brian :) im trying to understand how to connect a cpld "epm3034 or *3064" to a parallel nor flash but pinouts"names" on cpld and flash arent the same ive been searching all over the ne...
9 years agoConnecting a parallel flash to achieve what?
The CPLD will do nothing unless you download a logic configuration you designed before. The function of each pin will be defined in your logic, e.g. address signals driving the flash address lines. You can give each pin a symbolic name according to it's function, may be equal to the connected flash pin name.
