15 years agoCounting the position of ones in a binary vector
I want to design a combinatorial circuit for an fpga which will count the position of ones in a 16 bit vector. eg1 if vector is 16'b0000_0000_0011_0101 then output should be 64'h0000_0000_0000_5...
15 years ago --- Quote Start --- This is a "bug" thats been around a while, and have mentioned on our internal wiki. --- Quote End --- Thanks for clarifying. According to josyb, it has been already fixed in V9.1SP2. I accepted the limitation when working with previous Quartus versions and didn't yet figure out, if a variable slice range is required by the VHDL standard. Do you know the exact paragraph in IEEE 1076?
