15 years agoCounting the position of ones in a binary vector
I want to design a combinatorial circuit for an fpga which will count the position of ones in a 16 bit vector. eg1 if vector is 16'b0000_0000_0011_0101 then output should be 64'h0000_0000_0000_5...
15 years agoWow, a lot of activity while I was away ...
I only added the input and output registers to measure the speed (in TimeQuest you don't get tPD reports unless you set constraints and I was doing this test in QII 10.1SP1) and second to give the compiler a fair chance to get a high speed. Double registering the outputs may even help a bit more. While driving home from the office last night I mused that I could have written it as a function giving a better view:
library ieee;
use ieee.std_logic_1164.all;
use IEEE.numeric_std.all;
entity bitpos is
generic (
WIDTH_D : positive := 16
port (
Clk : in std_logic ;
data_in : in std_logic_vector(WIDTH_D - 1 downto 0) ;
data_out : out std_logic_vector(WIDTH_D * 4 - 1 downto 0)
end bitpos ;
architecture a of bitpos is
function reportbitpos( v : std_logic_vector)
return std_logic_vector
is
variable j : natural ;
variable r : std_logic_vector(v'length * 4 - 1 downto 0) ;
begin
j := 0 ;
r := (others => '0') ;
for i in 0 to v'high loop
if v(i) = '1' then
r(j*4+3 downto j*4) := std_logic_vector(to_unsigned(i,4));
j := j + 1 ;
end if;
end loop;
return r ;
end function ;
signal ld : std_logic_vector(WIDTH_D - 1 downto 0) ;
begin
process(clk)
begin
if rising_edge(Clk ) then
ld <= data_in ;
data_out <= reportbitpos( ld ) ;
end if ;
end process;
end a ; At the same time I added the generic to find out when we cross the 266 MHz border, at width 8 we get about 200 MHz, at width 4 500MHz+ or maximum speed. A fully pipelined design will need about 1280 registers, and run at maximum speed. Using a Cyclone IV E in stead of a Cyclone II ups the speed form 110 to 121 MHz for a 16 bit input vector (with a tCK setting of 8.0 ns) Compiling it for a width of 8 it gets up to 237 MHz. to FvM: --- Quote Start --- The assignment to the slice lq(j*4+3 downto j*4) isn't accepted at least by my VHDL version, I think a slice must generally needs a constant range. I used a bitwise copy instead. --- Quote End --- I used the VHDL 1993 setting in QII 9.1SP2 that I use for waveform simulation. Actually 9.1SP2 produces a faster circuit then 10.1SP1.
