15 years agoCounting the position of ones in a binary vector
I want to design a combinatorial circuit for an fpga which will count the position of ones in a 16 bit vector. eg1 if vector is 16'b0000_0000_0011_0101 then output should be 64'h0000_0000_0000_5...
15 years ago --- Quote Start --- Case statements would only inflate the code. josyb has shown an exact solution of your original problem, taking advantage of the VHDL iteration constructs. If you want a pure combinational solution for some reason, you can simply remove the if rising_edge(clk) condition. The assignment to the slice lq(j*4+3 downto j*4) isn't accepted at least by my VHDL version, I think a slice must generally needs a constant range. I used a bitwise copy instead. The suggested solution gives the results specified in your original post. --- Quote End --- That code will give me the solution but i cannot buy that because i dont know what circuit it will boil down to and so i cannot guaranty that it will work at 266 MHz. Can you tell me what circuit it will amke out of that for loop ?? Thats why i want a gate level circuit..
