14 years agocounter VHDL
hi,
i am trying to make a counter using the 50Mhz clock on my board DE1, when iLIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
ENTITY teller IS
PORT (
clock : IN STD_LOGIC:='1';
output1 : buffer STD_LOGIC;
output2 : buffer STD_logic
END teller;
ARCHITECTURE BEHAVIOR OF teller IS
signal counter: integer range 0 to 50000000;
begin
output2<=clock;
process(clock)
begin
if(rising_edge(clock)) then
if counter =50000000 then
output1<= not output1;
counter<=1;
else
counter<=counter +1;
end if;
end if;
end process;
END BEHAVIOR;
the output2led is half output power, but the out 1 led should flash +- 2/sec. but the led is always on. when i set the counter range to 5 and connect the clock to a pushbutton, it counts and at 5 the led turns of and on after 10.... why doesn't it work on the 50Mhz clock? thanks jeffrey2 Replies
the output2 looks like its half power because its flashing at 50MHz, with 50% on and 50% off time.
have you connected the clock to an actual clock pin? - Altera_Forum
problem solved thanks
