17 years ago
Counter Problems
im trying to implement a counter which counts positive, negative, or both edges of an incoming signal. It works, but if I give 10000pulses to it it counts only between 9980...9997. The internal FPGA clk is 10MHz and the signal to count comes along with 1kHz and a ontime of 50usec.
Here is the counter part:
Detect_Edges : FOR i IN 1 TO nbr_of_Counters GENERATE
PROCESS(Clk_I, reset_I, Enable_S, CntEdge_S, DIO_Stati_I, CountPort_S)
VARIABLE was_on : boolean;
VARIABLE cnt : integer;
BEGIN
IF reset_I = '1' THEN
cnt := 0;
was_on := TRUE;
ELSIF rising_edge(clk_I) THEN
IF ResetCounter_S(i) = '1' THEN
cnt := 0;
was_on := TRUE;
ELSIF Set_Counter_S(i) = '1' THEN
cnt := CONV_INTEGER(unsigned(CntSet_value_S));
ELSIF Enable_S(i) = '0' THEN
NULL;
ELSIF DIO_Stati_I(CountPort_S(i)) = '1' AND was_on = FALSE THEN
was_on := TRUE;
IF CntEdge_S(i) /= COUNT_ON_FALLING_EDGE THEN
IF CntDir_S(i) = '1' THEN
cnt := cnt + 1;
ELSE
cnt := cnt - 1;
END IF;
END IF;
ELSIF DIO_Stati_I(CountPort_S(i)) = '0' AND was_on = TRUE THEN
was_on := FALSE;
IF CntEdge_S(i) /= COUNT_ON_RISING_EDGE THEN
cnt := cnt + 1;
ELSE
cnt := cnt - 1;
END IF;
END IF;
END IF;
CntValues_S(i) <= CONV_STD_LOGIC_VECTOR(cnt,32);
END IF;
END PROCESS;
END GENERATE;
Has anyone an idea?
If i count the pulses with an other counter the# is correct
    Now it works. The problem was the unsynchronised signal. When i register it, as batfink wrote there ar no more problems!
    Thanks again
    thanks for your fast response!
    The Signal which i want to count is asynchrounous!
    I'll test the process you wrote.
    Patrick
    Yes indeed, but I have assumed the signal is synchronised already
    I'd add to Kaz's reply by saying that I'd pass in_signal through two registers and not present the "raw" unsynchronised signal to any logic, in order to avoid metastability:
    in_signal_d <= in_signal;
    in_signal_dd <= in_signal_d;
    and then:
    if in_signal_d /= in_signal_dd then
    (I'd also probably separate the code out into two processes but that's just my personal preference).
    Your code is too nested and complicated...
    the following idea of counting may help
    signal count : signed(32 downto 0);
    signal temp : signed(1 downto 0);
    process(reset,clk)
    begin
    if reset = '1' then
        in_signal_d <= '0';
        temp <= "00";
        count <= (others => '0');
    elsif rising_edge(clk) then
       in_signal_d <= in_signal;  -- your incoming signal
       if count_up = '1' then
            temp <= "01";        --   +1
       else
           temp <= "11";         --   -1
       end if;
       if in_signal /= in_signal_d then   -- either edge
          count <= count + temp;
       end if;
    end if;
    end process;
    cnt <= std_logic_vector(count);
