14 years agoCould some one explain some thing in this schematic please :)
Im very new to FPGA's and am using this attached schematic to crib from. every thing makes sense apart from the following FPGA pins pins 26,81 held high to 1.2v pins 27,80 held to ground ...
14 years ago --- Quote Start --- once i have checked over my design is it ok if i upload the schematic for you to have a quick once over? it is very simple. --- Quote End --- Yep, no problem. When you draw your schematic, use text to add notes, eg., add a list of reference documents like the handbook and pin connections guidelines, and notes that you have followed their recommendations. This helps a reviewer quickly understand that you have reviewed the FPGA literature. Here's an example to give you ideas: http://www.ovro.caltech.edu/~dwh/carma_board/gda06rb004_carma_v0.87_dec03.pdf Cheers, Dave
