14 years agoCould not find rtl_work.TB.vhd
Hello, The same process is giving issues once again: # ** Error: (vsim-3170) Could not find 'C:\Users\Alfonso\Desktop\PFC\simulation\modelsim\ rtl_work.TB_PFC_main'.# Error loading design...
14 years agoAs promised, here is an example of how to setup Quartus to synthesize against the fixed-point package compiled into the ieee_proposed library, i.e., the original library files are not modified.
VHDL fixed-point package synthesis example
9/13/2012 D. W. Hawkins ([email protected])
This design shows a minimal example that uses the
IEEE proposed fixed-point packages.
During synthesis, there will be warnings in the Quartus message
window about the design not meeting timing. This is to be expected,
as there is no .SDC file included in this example. This design is
not meant to be downloaded into a device, its merely to show how
to setup Quartus to use the fixed-point package library.
To synthesise the design:
1) Start Quartus
2) Make the Tcl console visible using
View->Utility Windows->Tcl console
3) Change directory to the location of this example code,
eg., if the zip file was unzipped into
c:\temp\vhdl_fixed_pkg_example, then at the Tcl console type
cd {C:\temp\vhdl_fixed_pkg_example}
The paranthesis {} allow the Windows path separator '\'
to be used in the name, otherwise you need to use '/', i.e.,
cd C:/temp/vhdl_fixed_pkg_example
4) Then source the file
source scripts/synth.tcl
The Tcl script will output its progress:
Synthesizing the 'fixed_pkg_example' design
- Quartus Version 11.1 Build 216 11/23/2011 Service Pack 1 SJ Full Version
- Creating the Quartus work directory
* C:/temp/vhdl_fixed_pkg_example/qwork
- Create the project 'fixed_pkg_example'
* create a new fixed_pkg_example project
- Creating the VHDL files list
- Applying constraints
- Processing the design
- Processing completed
The synth.tcl script has configured a Quartus project. After this
point, you can edit files (eg. change parameters in fixed_pkg_example)
and press play on the GUI to re-synthesize the design.
5) In the Quartus GUI, on the left-side is the "Project Navigator"
window. The "Hierarchy" tab will be selected.
a) The "Hierarchy" window has a slider bar along the bottom.
Slide it and you will see that this simple design requires
a single DSP Block in the Cyclone IV E device.
b) Click on the "Files" tab. There will be four files listed:
fixed_float_types_c.vhd
fixed_pkg_c.vhd
sfixed_multiply.vhd
fixed_pkg_example.vhd
These files are listed in the order they are compiled. The
packages need to be compiled before any files that use them.
Select the fixed_float_types_c.vhd file, right-click, and
select "Properties". Note that the "Library" field is
ieee_proposed. This is the VHDL library that the
fixed_pkg_c.vhd code expects to find type definitions,
i.e., at the top of the file fixed_pkg_c.vhd is the lines
library IEEE_PROPOSED;
use IEEE_PROPOSED.fixed_float_types.all;
Cheers, Dave
