15 years agoCosine and Sine lookup table in vhdl
Hi i'm new to vhdl and I need a cosine and sine lookup table file in vhdl file already DONE.. because I don't have much time.. please help! thanks.
It's encrypted if You don't have a license, but still You can use it for development.
--- Quote Start --- It is IP core. Like all cores from Altera. --- Quote End --- I can use with the Web edition, but i dont modify the core, is right? :) - Altera_Forum
--- Quote Start --- Or just use NCO. --- Quote End --- But is not a IP Core? Have restrictions! - Altera_Forum
Or just use NCO.
--- Quote Start --- Apart from writing assignments for each table value, you can consider the more elegant ways provided by VHDL to calculate it in a few lines of code. Different ways have been previously suggested at Altera Forum, just one example http://www.alteraforum.com/forum/showthread.php?t=1902 --- Quote End --- But it not include the "Symbols" of the design (project) of Quartus II? its pure the VHDL :) - Altera_Forum
Different ways have been previously suggested at Altera Forum, just one example http://www.alteraforum.com/forum/showthread.php?t=1902 - Altera_Forum
--- Quote Start --- Thank You for your time and for the answer! :-P - Altera_Forum
--- Quote Start --- Unfortunately that one was made using Spartan-3E and as You can see - a year ago. I've moved to Altera since then :) --- Quote End --- But don't have any document with specifications or algorithms, documentation ? Or you have the project of Xilinx ISE, can i open this and verify! :)
