15 years agoConverting from AHDL to Verilog
After 15 years of writting AHDL programs, I am switching to Verilog. In my AHDL programs I normally have the "top" or "main" program contain the include statements , then I/O pin assignments, and finally I/O port assignments for the many lower modules. There is usually no logic in the top level file. I have read many books and tutorials but have not found a good example on how to create this structure in Verilog. Is this the right approach for doing hierarchical design in Verilog. Any tips or examples would be appreciated. Thanks!!!!!3 Replies
Parameter is optional literal for readability to be used locally inside the design instead of directly embedding numbers (dec/binary or octal or hex) for example. - Altera_Forum
Thanks a lot! A quick question, if "module my_design (a,b,c,d)" is the top level why does it have parameter after it? thanks again!:confused:
I did verilog ages ago, I used the following template, I hope it will help but may need considerable updating:
// A sample Verilog program structure ‘include “file1.v” // lower module macro ‘define “my_line” 16’hBB7F // line macro //design IF module my_design (a,b,c,d) input a,b; //direction,width,name input c; output d; //internal design declarations // reg d; //output registered wire w1,w2 //for instantiation or node wiring integer I; //general use e.g. loop index parameter k = 4’b1 //literal ‘include “file2.v” //macro replacement function f1; input a; parameter k = 8’10001110”; integer n; begin Sequential statements... end endfunction task t1; input a; output b; parameter k = ‘8b11110000”; begin Sequential statements... end endtask //start of design //instantiations Lower_mod1# (5,8) mod_1(w1,w2); //positional association Lower_mod2 mod2 ( .a (w1), .b () ); //named association //wiring assign w3 = ~(a & b); //continuous assignment //intial values initial begin ... end //seq like process of vhdl always @ (a or b) begin ... end endmodule
