8 years agoContraining source synchronous interfaces
Hello all! I'm trying to understand how to constrain source synchronous interfaces and I'm having some difficulties. Could someone please explain the following: When we have two fl...
8 years ago --- Quote Start --- Ok, but why is then setup relationship=0ns at the FPGA input? --- Quote End --- At the FPGA io you can play some games to achieve timing. option 1: usual default behavior i.e. latch on next edge option 2: same edge launch/latch; if that helps timing No 2 is possible because as long as data stream is sampled correctly it doesn't matter if delay or advance is introduced. In this case the fitter will see if it is achievable or not.
