17 years agoConstraints from LVDS blocks and logic
I have a lvds tx and rx blocks in a Stratix3. There a 20 bits with deserialisation factor of 4. With the Rx side, the data leaving the lvds is registered. The lvds and registers are using clocks from a PLL. TimingQuest gives me an erro and show the sclkout rising edge as the source clock but with the rising edge of the register clock directly underneath. I've used the write sdc command and got the lvds constraints it generates. However, they just don't seem to cover this path between the sclkout and the registers. I would have though that the hold time would have been 4 sclks. I do have a clock mux on a couple of outputs from the PLL and it's the output of the mux that drives the registers. I don't know if this is cause a problem or not. If I put a hold time of 2, then problem goes away but is TimingQuest highlighting a problem? Regards MT
