12 years agoConstraint the path between CPU and FPGA
hi, all
I want to constrain the path between CPU and FPGA. Timing diagram bellow is cutting from the datasheet of CPU current contraints: 1. address latch enable input port, set_input delay for both rise and fall edge set_input_delay -rise -max -clock [get_clocks {CLK}] t11max [get_ports {ALE}] set_input_delay -rise -min -clock [get_clocks {CLK}] t11min [get_ports {ALE}] set_input_delay -add_delay -fall -max -clock [get_clocks {CLK}] t21max [get_ports {ALE}] set_input_delay -add_delay -fall -min -clock [get_clocks {CLK}] t21min [get_ports {ALE}] 2. ship select input port set_input_delay -rise -max -clock [get_clocks {CLK}] t24max [get_ports {CPU_CS1 CPU_CS2}] set_input_delay -rise -min -clock [get_clocks {CLK}] t24min [get_ports {CPU_CS1 CPU_CS2}] set_input_delay -add_delay -fall -max -clock [get_clocks {CLK}] t14max [get_ports {CPU_CS1 CPU_CS2}] set_input_delay -add_delay -fall -min -clock [get_clocks {CLK}] t14min [get_ports {CPU_CS1 CPU_CS2}] 3. read and write input port set_input_delay -rise -max -clock [get_clocks {CLK}] t20x [get_ports {CPU_WRH CPU_WRL}] set_input_delay -rise -min -clock [get_clocks {CLK}] t20n [get_ports {CPU_WRH CPU_WRL}] set_input_delay -add_delay -fall -max -clock [get_clocks {CLK}] t10max [get_ports {CPU_WRH CPU_WRL}] set_input_delay -add_delay -fall -min -clock [get_clocks {CLK}] t10min [get_ports {CPU_WRH CPU_WRL}] 4. FPGA-TO-CPU data output port set_output_delay -clock {get_clocks {CLK}} -max t30 [get_ports {CPU_D}] -add_delay set_output_delay -clock {get_clocks {CLK}} -min t31 [get_ports {CPU_D}] -add_delay Are the constraints above correct? And I'm little confused how to contrain CPU-TO_FPGA input port? ThxNo RepliesBe the first to reply
