10 years agoConstrainst for data launched by negative edge
Hi, What is the correct way to constrains source synchronous inputs in this case:External device provides clock with data. External device launches data on falling edge. FPGA latches dat...
10 years agoHello,
Here is what I would do if I am there. (1) I would take one pll with following parameters: -> Mode : Source synchronous mode ( https://www.altera.com/support/support-resources/operation-and-testing/pll-and-clock-management/pll-glossary.html#source_synchronous_mode ) -> Input clock : Clock which is coming from external device -> Output clock 0 : With same frequency as input clock (2) Then I would use pll's output clock 0 to sample incoming signals. My SDC file would have following constraints : # Base clock create_clock -period "100MHz" -name CLK_IN [get_ports CLK_IN] # Virtual clock create_clock -name CLK_IN_VIRT -period "100MHz" # Deriving PLL clocks derive_pll_clocks # Derive clock uncertainty derive_clock_uncertainty set_input_delay -clock [get_clocks CLK_IN_VIRT ] -clock_fall -max $in_max_value [get_ports {DATA*}] set_input_delay -clock [get_clocks CLK_IN_VIRT ] -clock_fall -min $in_min_value [get_ports {DATA*}] I have assumed here that incoming clock is continuous. is this correct? I am learning these timing constraints. So, feel free to share your opinion if you have any concern. Thank you, Bhaumik
