14 years agoConstraining ic delays
Hi all,
I am synthesising my project and i am having timing violations wrt to IC delays. My cell delays are under control but dont know why even after adding a proper sdc the tool is not able to meet setup. I know the tool does add additional delays to meet the hold requirements but my priority is setup and i also have switched off the "optimize all hold paths" constraint. The cell delays in a path is around 2ns while the IC delays shoots upto 5ns. I dont want to use a logic lock constraint is there any othe way to meet 200Mhz for this path even if i take a 60-40 ratio of IC- CELL delays in each path. The sdc is cross checked and i have entered my requirements properly. THANKS12 Replies
okkk thanks RYSC you were a gr8 help to me..will try your ideas...thanks..
One more question RYSC can over constraining help...i mean i want to meet 200 Mhz and i ran the design with 250 Mhz ..
