14 years agoConstraining ic delays
Hi all, I am synthesising my project and i am having timing violations wrt to IC delays. My cell delays are under control but dont know why even after adding a proper sdc the tool is not able ...
14 years agoOk i get you...i know you strongly recommend virtual clock and i also tried using it but failed badly...I have two problems in understanding virtual clock that you have often suggested to many.
1. The advantage 2. If i am not feeding the clock to any port how will it constraint my design. How will the tool know the frequency it has to meet. I know that the problem lies with my understanding and thats why i couldnt use it although i really want to know the advantage of it. I will also try your suggestion using input and output delays only to driving ports and can you also tell me the correct way of using pll I also tried using pll but maybe the correct syntax is wat i am failing in and yes one thing would like to mention that the reports are generated in ARRIA V.
