14 years agoConstraining ic delays
Hi all, I am synthesising my project and i am having timing violations wrt to IC delays. My cell delays are under control but dont know why even after adding a proper sdc the tool is not able ...
14 years agoHi RYSC..i did what you said but this was not the path i was talking about.
Here as you can see the datadelays is good but because of the clock skew my timings are failing. Because of this clock skew i had to shift my analysis to data delays and not the report timing. I use report_path option and check whether the data delays are within my clock periods. I dont know whether my analysis is correct but still would like you to guide me. I am attaching the reports you wanted and yes the path is reg to out and the output port is made virtual.
