11 years agoConstraining an SPI interface
Hello all, What is the proper way of constraining a 4-wire SPI master interface? I have several devices connected to my SPI bus, and fastest one can accecpt a SCLK up to 33 ns period, with setu...
11 years ago --- Quote Start --- Any suggestion on how? I tried several ways but no one seems to work... --- Quote End --- Typically I start with the error message from TimeQuest and work out what signal it is complaining about. I'd start by using the signal name in the error and see if adding a generated clock helps. If it does, then I'd figure out a cleaner (more generic) way to determine the clock using the TimeQuest Tcl functions. Cheers, Dave
