11 years agoConstrain combinational delay in Timequest
Hi, I am trying to design an asynchronous system using FPGAs (I know it is not advisable). I need to be able to constrain the combinational delay between a pair of nodes/keepers. Does Quartus p...
11 years agoHi Tricky,
Can the set_max_delay command constrain the delay between two combinational components. I believe the set_max_delay command modifies the default setup relationship between two FFs Regards PD
