11 years agoConstrain a generated clock
I have a generated clock (derived from a PLL) that is used in the FPGA and also feeds an output pin. The clock is constrained using derive_pll_clocks TimeQuest reports the clock outp...
11 years agoI've added a create_generated_clock for the clk_out pin and also set a false path to the pin. TimeQuest no longer reports the output as being unconstrained, the code fully meets timing and runs correctly.
Thanks for your assistance.
