15 years agoConstant Value overflow
I have the following Warning:
Warning (10639): VHDL warning at FRAME_ROTATOR_NEW.vhd(391): constant value overflow It's aboutelsif main_cnt >= to_unsigned (74877906940 , 39) then and i decleared main_cnt as signal main_cnt : unsigned (38 downto 0) := (others => '0'); Where did i go wrong? Or is the warning caused somewhere else? To make it easy for u 74877906940 decimal = 116F122FFC HEX = 37 bit3 Replies
In Quartus and most other VHDL tools, integer literals are limited to 32 bit, although the VHDL standard would allow a larger range. Bit string literals have no limitation, but unfortunately, the supported formats are only binary, octal and hexadecimal, not decimal.
I'm aware of the limit for integer. But does that count when i use it in this way ?
Aparly it does, cause is get the warning :). I'll try something.
That does the trick. Thxelsif main_cnt >= "111" & x"FFFFFFF" then - Altera_Forum
I am not sure but possibly VHDL has a limit on integer values (2^34 may be...)
