16 years agoconnection to pc...
i have some input pins that i need to drive the fpga, what is the simplest connector from the fpga to the pc. thanks
16 years ago1. i am a student that designing a board .....
pc and drive signal (clk ,high , low etc.) from the pc to fpga....... i looking for the hardware solution and software (quartus???) solution. Microsoft Visual Studio - C++ or VB can do this job for PC side. OUTPUTS - You can genetate clock, High Level, Low level. INPUTS - You can read High and Low level signals. Not Clocks. It all depends on what you want to do and How much resources - time / money you have. 2. i am a begginer so if you can please write me a long and simple answer i will be appreciate it very much . thanks.... As a beginer and student it may be difficult to learn and write code in C++. GKM
