16 years agoconnection to pc...
i have some input pins that i need to drive the fpga, what is the simplest connector from the fpga to the pc. thanks
16 years ago --- Quote Start --- What is it you're trying to do? You could use - - GPIO pins connected to a parallel port of a PC - An RS-232 transceiver and a DB9 connector to connect to a serial port of a PC. Anything beyond that would not fall in the simple category. --- Quote End --- thanks... so i can use UART??? which pin of the fpga are GPIO??? how can i make quartus2 to know that i connect with UART and to drive signals to the fpga??? thanks hagico....
