16 years agoconnection to pc...
i have some input pins that i need to drive the fpga, what is the simplest connector from the fpga to the pc. thanks
16 years agoWhat is it you're trying to do? You could use -
- GPIO pins connected to a parallel port of a PC - An RS-232 transceiver and a DB9 connector to connect to a serial port of a PC. Anything beyond that would not fall in the simple category.
